engine is hunting
Started by Madden, August 13, 2005, 04:57:08 PM
JayDee
You can unplug it, but you may have to adjust the idle up a bit using the screw on the throttle body. It is suppose to kill the cat if you do not have the pump connected, I do not see why as other cars run without a pump and it turns off at 3K anyway.
Jason
Madden
Will be removing cat soon anyway.  So its safe to just unplug it cool
Cheers For all you help
Jamie
Madden
hello have disconected  the air pump and now the car is hunting on idle.  The clutch on the aor pump is shaged as it still catchs tiny bit even with its unpluged?
Carl
Drop your idle now,the ecu is trying to settle it,but the screw will be too high,so they are both fighting each other.
If you are decatting then take the airpump off and run a shorter belt.
Don\'t forget that if you run no cat you may need an ecu upgrade.
Regards
Carl
Madden
hello i have tryed adjusting for idle at it wont stop hunting at idle runing really bad.  I have pluged it back in again it all is fine.    why would the car be hunting with the air pump disconected?
Jamie
