Ball joint removal on front suspension
Started by FD3Typer2, July 30, 2005, 07:38:13 PM
FD3Typer2
Hi,
I am in the process of doing some work on my car engine and suspension wise. I am replacing all the bushes front and rear. I have disassembled the rear completely without any drama, but on the front I am having a problem removing the lower arm ball joint on one side, and upper + lower arm ball joints on the other. Mazda service manual says use an SST. I bought a ball joint separator from Machine mart and that broke while tightening down ( I left the nut on the bolt to protect the thread.)
Is there a trick or other tool I should use? I have seen those forks but am worried that they will destroy the boot.
Any help from you guys is appreciated, I really want to get those arms off so I can change the bushes and polish up the arms!
Trevor
asp
the forks r a good little tool.some times thay do rip the rubber seal.
the forks hav a grove cut out of them on 1 side so\'s not to brake the seal.
i heat them up and thay pop straight out with a tap from a hammer,
spray tham with wd40 the day b4 u want to take tham off.works good
