Gearbox filler plug
Started by nikp, July 07, 2005, 10:31:02 AM
nikp
Hello - does anyone know what tool or socket adapter, or whatever, i need to use to undo the gearbox filler plug?
(I would phone Shy, but i think i\'ve bugged them enough!  :p )
Cheers!
goose
Mines just a square nut type plug. I used an imperial adjustable spanner, but I\'m sure a metric one will work just as well. :)
You\'ll need some way of pumping the oil into it to, it\'s not easy to get to!
nikp
Cheers!
Yeah, i know about the oil situation. I\'ve figured out that I shall get an old fashioned oil dispenser \'thing\' from halfords - they have flexible necks, so should do the trick! Might be there a while though, what with having to pump 2.5 litres of oil!
goose
Sounds like the sort of thing I used. Made by Draper and very crap.
Prepare to get messy!
nikp
Rich Cheung
Did mine using funnel and tubbing from the engine bay and didn\'t take too long. Had to fill from the check level though as the filler bolt head was completely smoothed.
Phasen sehnen sich das Hoff
長くHoff は住んでいる
