air con charge
Started by ozzyvelcro, June 22, 2005, 07:04:20 PM
Tintin
What ar you supposed to see in the sight glass ???
I don\'t see anything in mine its just empty , air con works fine , just wondering if it needs servicing
12.8@110.64 at RS4:Thumbs-up
ozzyvelcro
you should see nothing if its working fine.if you get someone else to switch it on while you watch you will see some bubbles then it will go clear when the system gets up to pressure.
Cheers Danny
Tintin
cheers bud , I\'ll get the missis to flick it on and check
