Radiator fans
Started by Eddie, July 05, 2005, 12:56:08 PM
Eddie
Hi I was wondering if someone can help me, I have just fitted a trust FMIC and re-posistioned my rad, problem being I have only just realised that the two connections for the fans are identical., one connector from each fan.
Just wondering if anyone knew if they had to be pluged in a specific way round, I ask because if they dont why did they not just make one connector?
Hope this makes sense:) to someone.
THanks
fro
I\'ve just done the same. As far as I can see it doesn\'t matter which way round they go. In fact, I purposely swapped mine to get more reach :)
davegttph1
would 1 be something to do with the air con? when you turn the air con on 1 of the fans should start up. probably why it has seperate wiring....
