3rd gen 02 sensor test
Started by 907, May 31, 2005, 04:05:43 PM
907
Does any one know how to test the O2 sensor (single wire type)on an a 92 fd3s jap import,
Also is it possible to turn the sensor off with a power fc.
Cheers for your help.
asp
yes & yes.i think its tested buy volts some how.
some body lata will probly reply with the volts readin.
907
good, any idea how to turn it off with the power fc the manual has turned my brain to mush.
907
Im slowly learning how to use the power fc and the voltage reading from the O2 sensor is 0.64v, am I right in thinking that that means its broken.
