Oil Pressure Gauge
Started by PCCarter, July 11, 2003, 06:55:28 PM
PCCarter
Can anybody please advise what the oil pressure gauge is supposed to indicate when the car is started .
Thanks for your help
MikeLMR
PCCarter
Sorry a bit new  to this.
RX7 3RD Gen.
Hi Paul ,
Whats yours reading ?
Might be worth you knowing that at times some cars  read zero when hot , this is normaly a dirty conection on the terminal on the sender unit and not an internal problem.
All the Best Clive
PCCarter
Hi Clive
That sounds about right, seems to be very intermittent.  Do you know (silly question i\'m sure) where it is located so I can clean as suggested.
Paul
Hi Paul from memory it\'s a spade terminal  just under the base of the oil filter , if l am wrong let me know.
Hope this helps .
Clive
