Advise needed on Apexi.
Started by jamie_eaton, April 26, 2005, 07:38:43 PM
jamie_eaton
Hello guys right i could do with some help here.
I have an Apexi Ecu and comander on its way and was just wondering about some of the other Apexi do.
If i am getting the comander with the ecu is it right in thinking there is no point in getting the SAFC II.
Will my comander control and do the same as the apexi SAFC II.
Also i was going to upgrade my hks boost controler to the   HKS EVC  5th generation of the coveted HKS Electronic Valve Controller. Any one have this?? is this better than the the Apexi AVCR??
memski
The safc is basically just a fuel controller - it won\'t allow adjustment to ignition so you\'re right in saying you won\'t need it, pfc will do the same job and more. The commander allows you to monitor and adjust various parameters.
Got a hks evc3 already in my car, not had to use it just yet so can\'t give you any feedback on it - had the apexi avcr in previous cars and however pretty it is I found it didn\'t control boost as well as I\'d like. Profec B if I was doing it all over again, nice and simple :)
