very strange
Started by davehg, July 09, 2005, 10:51:47 AM
davehg
just put theengine back in the car and changed the fuel filter at the same ime, now the filter was full of cr4p inside i cant see how fuel ever managed to pass through it, anyway now the car seems to bog down at times and go onto one rotor, could it be that its now overfueling in some areas,  also from time to time it will show up some knock between 50-70 again is this fueling related?
the car is running a pfc with 1600 secondaries and lots of other mods.
thanks
If you had it set up with a blocked Fuel fillter then there is a good chance it will be overfueling.
This is the reason why most good shops service the cars before setting them up.
Chris
