Help fitting Defi gauges
Started by FC3Sleo, April 19, 2005, 11:52:10 AM
FC3Sleo
can anyone help me with a few questions? got defi oil temp,  oil pressure, egt and water temp gauges. was wondering if i plug both oil temp and pressure sensor in the Greddy sandwich plate?? and where is the best place to put the egt sensor and does anyone know what diameter hose adaptor do i need for the water temp sensor? this is for a TII btw.
rx7veilside
oil temp and oil pressure go into greddy adaptor..egt if u havnt allready done so u can either tap the downpipe or weld a boss on and use that..water temp either split a hose and put adaptor pipe(demon tweeks) and put defi sensor in there or tap the coolant bottle in some way
FC3Sleo
cool, so i can mount the egt anywhere on the downpipe or does it have to be close to the turbo?
