fuel filter change
Started by rmagictastic, April 13, 2005, 08:31:05 AM
rmagictastic
Mornin all,
after my small diesel incident i gotta change the fuel filter, i hear it is a b*tch of a job, anyone done it???
tar
Nick
Getting old... Its not like it was in my day!
DRAGON
Fuel filter removal and installation
Additional Tools required
Ratchet 10mm socket and extension
Pliers long nosed and normal
WD40 lubrication
1x jack
2x axle stands
·   Drive the car onto a flat suitable surface and jack the rear of the car up, easiest jacking point is in the centre of the rear differential, place axle stands underneath the sills about two inches away from the wheel arch
·   Release the fuel pressure by opening the fuel cap and allowing the vapours to be released
·   Go underneath the rear of the car and remove the two rear guards there are five 10mm bolts holding these shields in place, remove both shields and put out of the way thread the bolts back into its holes a few threads
·   Now you can see the fuel filter it is located above the differential with two fuel lines going to it
·   Remove the first fuel line which is located on the drivers side of the vehicle simply remove the clip down the line and pull the hose off the fuel filter but be careful as some fuel will come out so plug the hose up with a suitable sized bolt
·   Next is to dismount the fuel filter there are two 10mm bolts holding it in place, you can get to these through the sub frame using a ratchet these are not the bolts that go into the chassis they go into the mounting bracket on the back of the filter undo these and the filter will come away from the bracket
·   Now you can remove the other fuel hose pull the clip away and pull away the hose more fuel will pour out, the filter is now totally free and you can take it out from underneath the car
·    Once in the light remove the fuel filter from its bracket undo the 10mm bolt on the back of the bracket make sure to take note on which way round it is mounted and fit the new one to the bracket
·   Install back onto the car you may use some lube to get the fuel hoses back on attach hoses and clips and bolt the fuel filter back into place not to tightly the mounts are rubber so they will flex and break
·   Make sure the hoses are on correctly and turn the ignition on to prime the fuel system, check underneath the vehicle for any signs of a fuel leak do this a few times just to be certain and then if all is fine then put the covers back on and place the car back on the floor start the car and your done
rmagictastic
you sir are a gentleman and a scholar!!!
This should be made a sticky, as its something that is a real pain to remember.
GeckoGareth
I started to do this using the workshop manual but it didn\'t mention anythign about removing guards so was as far as I could se impossible to get to.
Will give it a go ASAP.
cheers
Gareth
Donato
How often should you change these? I did mine last August...
cheers
Donato
rmagictastic
as far as i know you only change them after you fill the car with diesel.......DOH !!!
Donato
I did the exact same thing. On my way to Pips, half asleep at about 7am, (i had been driving since 4.30am) put ultimate diesel in it! Had to get it sucked out the tank, still made it to pips for 12 and got mapped! (had to endure the jokes about the only rotary diesel in britain...) :rollin
scooby_si
copied & stickied thread to FAQ section so if it\'s OK i\'ll lock this one shortly & any discussions can carry on there.....
Good stuff :god
Si
DRAGON
I have written up a oil filter change and also a plugs one, if anyone wants them I can post them up.
memski
Many thanks, a really good write up. I remember reading somewhere that the fuel filter needs changing every 15000miles?
scooby_si
Yeah cool Ross whack them up here if you like & i\'ll tweak move & overwise all the necessary (OK & maybe i might accidentally delete the entire forum in a moment of error :rollin lol) to the FAQ section....
Cheers boss
Si
gavin
good guide Ross i used it after i received my service kit from you and was a real help, theres no avoiding the petrol down your sleeve or a bit in your eye,
thanks Ross
