heat lamp switch
Started by Draco, April 01, 2005, 05:56:34 PM
Draco
just installed 3 defi gauges with the link. I got my ground and illumination from the dash light brightness switch and the perm live and ing live from the sterio.
      k now that works fine i installed the sandwich plate that goes between the oil filter so i can have the reading of the iol pressure/temp went to put oil filter back on but the plug that goes in the stepper motor and a little adjustable screw that is situated above the oilfilter was in the way so i unsrewed the screw and unplugged the plug...
        hay presto all finished. BUT now i have hte heat switch lamp on hte dashboard all the time. I have checked it out with my apexi fc commander and it is illuminated in there too!!!!!
       any ideas ( also what is that srew is it a idel screw as it is reving higher now).
any help apreacheated
rx7veilside
chris pop round tomorow afternoon and take a look at mine
Draco
ok cheers paul i will give you a call about 11/12  ish okies
rx7veilside
chris wont be in until 1300
K1HKS arse
#4
Stepper motor?I take it you mean the TPS switch on bulkhead side of throttle body and screw that is below/beside TPS switch.
Gary
Draco
yep thats the one i have sorted out the heat lamp switch ( pushed it in about 1mm more. now its just hunting maybe i have to play around with this screw a bit!
on another note kinda related . you guys that have these sandwich plates, do u have a smaller ( in height ) oil filters?
K1HKS arse
They hunt when the TPS switch is out of range or throttle body settings are played with.Did you adjust TPS switch,move it up or down,did you mark screw before you undone it so you know where it was before?You can see if TPS switch is out of range by looking on your commander under sensor check,you will need range settings from manual.
Gary
