ECU/De-limiter
Started by Steve Burnett, June 22, 2003, 12:11:46 PM
Steve Burnett
Hi,
driving down to knockhill on Friday I found out that the car still is limited to 115(ish) Do I need to fit a delimitter or is this something written into the ECU program?
richrx
ask BNA_ELLIS or MIGUEL, they should know.
Im pretty sure its a kit you need
You will need to fit a de-limitter.
Dan
Steve Burnett
Am I best to buy this from one of the usual suspects, RE:Worx, RX Motor, WGT or just from one of the performance places in the japanese mags? Any effects on the car other than stopping it from going beyond 115mph?
If you get it from one of the usual places, they will offer telephone support I would guess. Just in case you need it.
The only thing effect other than stopping it going past 112 mph, is that above this speed your mpg gets even worse. :D
Dan
Glenn Butcher
Another good way of doing this is purchasing an Apexi Rev/Speed unit.  See here:
http://www.autospeed.com/cgi-bin/browse.cgi?product=888800077
This is the newer generation unit.  Only thing is - that it appears to be in KM only.
Thanks,
skim41
take your instrument panel off, there is a connector with 12 wires cut the green/red one. Then you should be able to hit 175.
DId it with mine, no probs
Steve Burnett
Im looking to purchase this item for the delimiter.
Any thoughts on this or any ideas on fitting this as the instructions are in Japanease.
http://tinyurl.com/fa5a
Steve, even though the instructions are in Jap. you can normally work it out. They lay them out very well.
If not try giving one of the HKS dealers out there a call. Two I can recommend are Graham Goode (0116 2440080)  or Chris at HyperSR (0845 225 0111)
Dan
Steve Burnett
Has anyone fitted one of these? Anyone got a copy of the instructions? How easy is it to install?
Steve  :D
