fitting harnesses
Started by gavink, March 21, 2005, 06:28:47 PM
gavink
Hi....
I fancy a pair of harnesses in my rex..can you fit them when using the standard seats as i quite like them and dont really want to splash out £1000+ for a pair of decent bucket seats...
Also where can i attach them too bearing in mind i\'d like 3 point harnesses...
thanks
gavin..
iiyama
YOu have to change the rear strut bar for one from http://www.rotaryextreme.com/
Ian
babz_audio
are there any holes for rear seat belts??? as i have a harness coming soon and would also need advice on fitting it. cant get that rear bar in due to my install :(
RE:Amemiya RX7 R2 Single Turbo HKS T04R
e-mail: mo9797uk@yahoo.co.uk
iiyama
Rear seat belt mounting points are no good for harness\'. They are in the wrong place I think
babz_audio
thats a shame, no other way around it??? :(
Gerry M
my 4 point ones that came on the car from japan use the rear seat belt lower mount for the rear legs of the harnesses as far as i know, the seatbelt bolts are taken out & replaced with eyebolts, & as its the type with the seatbelt buckle on the legs it means i can still put the seat forward if i need to get anything out of the seat they\'re made by willians.
The tartiest rx in scotland
babz_audio
#6
thanks gerry, ive ordered myself a 4 point one so once i get around it i will share the information :D
maximtaylor
Just keep in mind that using the rear seat belt mounts means the shoulder straps will want to pull you down rather than hold you back! These straps want to be as close to horizontal as possible.
