Help, does anyone recognise these rims?
Started by Mike, May 27, 2003, 02:41:16 PM
Mike
Trying to find out the make and model of this wheel if possible to try (!) and get a replacement.
Any ideas anyone?  As a bit of a clue, they were on the car when imported so are originally from japan you\'d assume.  There are no obvious manufacturer markings on the rim.
Mike, take the wheel off and check the behind of the spokes. Make/size and offset is normally on the back of them.
Dan
Mike
Such a simple idea, but I never thought of that! Doh! :o
Cheers, will check the back of the casting tonight.  Lets hope...
Jus
Mike
Had a look for OZ Mitos - not the same wheel though.  Still haven\'t matched this wheel.
There are no identifying marks on the back other than some numbers and the word \'MAW\'.  There\'s stickers, but they\'ve worn out.
Next option is to get the tyre taken off the rim to see if there\'s any stickers there.
If not then its a new set of wheels for me - and I can\'t afford that along with the rebuild too!
