Help Needed On The Following
Started by p.robby, March 11, 2005, 01:27:24 PM
p.robby
HI, in the past week the following problems have occured,  can any one help or has anyone had the same problems,
~clutch pedal has started to stick. when released will only come up half way, then with a pull from my foot it clicks and comes up all the way.  this does not happen all the time and has no affect on the clutch(drive) itself.
~buzzing noise from what i think, to becoming from one of the rear Bose speakers. (stops when head unit is off)
~coolant buzzer comes on. Only in the past few days and ONLY on start up!!!   Stops within 5 mins.  Have checked,
coolant levels >  fine
leaks              >  had a good look
car drives fine
starts fine
fc commander reads fine
hope someone can help, had the car for over 1.5 years with no bad problems only within the last two weeks have these came to light.
cheers paul
Shark
QuoteOriginally posted by p.robby
Check the footwell first and make sure there\'s nothing catching the pedal - can;t sugest more than that for this one I\'m afraid.
Quote~buzzing noise from what i think, to becoming from one of the rear Bose speakers. (stops when head unit is off)
probably a wiring problem.  Check and make sure there is a good connection on each speaker cable at the head unit and at the speaker.  If fine then replace the speaker cable in question in case the cable itself is damaged.  If still same problem then I\'m lost - sorry.
Quote~coolant buzzer comes on. Only in the past few days and ONLY on start up!!!   Stops within 5 mins.
This one I recognise.  Had the same problem with my last FD once only.
I flushed the coolant and replaced it - taking hours to ensure that I burped all the air out fully.  then running, cooling down and topping up.
I had tried burping it to get rid of the problem but with no success.  replacing coolant solved the problem once and for all.
Hope this helps bud.
Gregor
[SIGPIC][/SIGPIC]
RX7 sold :(
