Remove And Refit Engine
Started by gyrpere123, June 21, 2003, 05:49:56 PM
gyrpere123
HELLO, JUST GETTING READY TO START REMOVEING ENGINE FROM MY WRECKED CAR TO FIT INTO THE NEWLEY ACCUIRED T11 CONVERT.DOES ENGINE AND BOX LIFT OUT TOGEHER AND REFIT TOGEHER OR DO THEY HAVE TO BE SPLIT. IS THEIR ANY NASTY SURPRISES WAITING FOR ME, ANY HELP MUCH APPRECIATED  CHEERS MARK.
MikeLMR
can\'t help with engine and box thing but ...
Take lots of pictures before you take anything appart and label up all the wires a sensors ... its the little things that are hard to sort out.
P.S Caps lock .. its the third one up on the left ;)
t2rew
when i took my engine out i left the box in but there is loads of room to swing the whole lot out together if you remove the rad
gyrpere123
THANKS FOR REPLYS. DOES ANYBODY KNOW IF ECU WIRING HARNESS COMES OFF ENGINE OR DOES IT HAVE TO BE DISCONNECTED FROM ECU UNDER DASH CHEERS MARK.
t2rew
i removed all the plugs from the engine but now if i had to do it again i would take it fron the ecu.
Glenn Butcher
Definitely disconnect the ECU from within the car (in the passengers side kick panel).
You will be there for a week doing it from the engine side (as there are loads of connectors on all parts etc.).
Once disconnected - it should pull through - then you can pull the engine and box out (obviously after unbolting etc.).
Thanks,
gyrpere123
Thanks for everybodys replys, engine and box now in place ready to be connected up ready for weekend.Thanks again MARK>
