..auto electrician.
Started by leggysrx7, November 02, 2004, 11:45:38 PM
leggysrx7
hi Pete
Any luck with the ecu#2??Did it fix the problem?
Marc
petemillis
I should know bt Friday if problem solved. Oxo has confirmed that the bit I\'ve got is the same as what he replaced to solve the problem.
I\'m now just waiting for the guy who\'s now got the Rex to let me know when I can pop over to sort it out. Probably be this evening or Friday evening. the moment I get back in I\'ll let you know if it did the job.
leggysrx7
..any news on whether or not this cured the fault, noticed the previous reply on my other post (strange fault) and the f100 cured the fault...same thing as the ecu#2???
..now i\'m all confused!
Marc
WeasleRx7
F100 appears to be the same thing as ecu2
petemillis
Yep, ECU #2 is the F100. Still haven\'t done the one I need to do......
petemillis
I have just spent 15 minutes swapping the ECU #2 over. The one I removed was the F110 and the one I\'ve put in was the F100. They both look identical and have exactly the same numbers on the boxes so I don\'t know what the difference is.
Anyway - everything works perfectly now. no more continual beeping/flashing seatbelt warning, and no more windows going in time to it. Spot on! Me HAPPY!
leggysrx7
..damn!! None left at RX motors..too slow of the mark!!Not to worry, seems i may be exchanging mine for someone else\'s..question is...what the hell does it look like??Anyone got pictures of the area..the unit..anything at all?????
...i know it took 15mins Pete, but i reckon it\'ll take me at least double that just to find the damn thing!!!!
....please help..again!!!!!
Marc
leggysrx7
..finally got round round to fitting my replacement ecu#2/F110..i now get a continual, constant bleeping for the ecu#2...the one i have in the car is a F110, but the replacement was a F100....should this matter??
Any more advice welcome?? I emailed RE:Worx for advice as i bought the replacement from them, wonder if the second hand was faulty too....
..what fun!!
Marc
WeasleRx7
Marc
I dont think it should matter really.  My duff one was a F100, which RX Motors exchanged for another F100 that also turned out to be knackered!  They then sent me out a 2nd replacement which was a F110 and this cured the problem.  Get RE:Worx to swap you over another box as it sounds like that one is faulty too.  If the next box you try doesn\'t work either, then there may be another issue.
You may be able to try one from a working car, if there\'s someone near to you who wants to help.
leggysrx7
#24
..think im gonna get a chance to use robbie\'s one in my car, hopefully that\'ll give me an idea whats going on..
Marc
petemillis
I took out an F110 and replaced it with an F100 from RX Motors. The F100 does make a continuous tone but only when the key is in the ignition and the door is open. It sort of says "don\'t forget to take the key out" and I think it may be intentional.
leggysrx7
..im sure i tried closing the door, but i can\'t really remember :(  I\'ll try again in the morning if it\'s dry, replacing the F110 with the F100......
cheers Pete.
Marc
