quickie - removal of front/rear reflectors
Started by Luciano, January 27, 2005, 03:06:03 PM
Luciano
Im replacing my side reflectors this evning - the rears screw on/off I guess, but the fronts - how do they pop out?
Cheers!
(will post pics when finished)
Eddie
I removed mine and I am sure I had to get access from the wheel arch, I did it a while ago but I remember a screw that had to be loosened and it could only be done via the wheel arch.
I could be getting totally confused and thinking of another car which is possible.
ro284
You are right Lee, i have just done mine, there is one of those press fit plastic bttons at the bottom of the plastic wheel arch inner cover, remove the centre with a small screwdriver, then the outer part, lift the plastic cover out of the way as high as the light is, and on the back of the reflector there is a phillips screw, undo this as far as poss, and pull out the reflector from its back end nearest the wheel, as it clips in with a hooked moulding at the front, The only problem i had was the screws were rusty.
Bob
