Main Menu
sizes
Started by sdminus, January 04, 2005, 11:31:06 AM
sdminus
Could somebody please tell me the dia of the pipe used between the stat housing and the ast and the ast and the rad (fd)
scott
sdminus
CLICK.......CLICK............CLICK...........CLICK
Sorry Clive not aimed at you
Scott:wave
Shaq
I think I know what pipe you mean, are you talking about the one I have circled in red ?
If so get an open ended spanner and place it on the pipe, find one that fits tight (so you cannot twist the spanner on the pipe)
I belive its ID 10 which is
ID = internal Diameter 10mm
shaQ
sdminus
Thats the one mate. I think it is 10MM int dia as well but silicon hose comes in 9.5mm and 11mm.   not sure if its best to squeeze it on ( but having a reduced internal area) or clamp it down real tight on a larger pipe.
scott
Shaq
yes samco only do a ID9.5mm i just bought mine from raldes, should be with me soon.
It should fit, will just be a bit tight, use like small Jubilee clips to hold it in place you should be fine.
shaQ
Donato
Use the 9.5mm, it supposed to be a tight fit. It leps it not to pop off. You can warm it with a hair dryer if it wont go but it should go on fine if you wiggle it.
Donato
sdminus
cheers boys
scott
