FC Single Turbo Advice
Started by Freddy, November 24, 2004, 03:14:35 PM
Freddy
Hi Chaps,
Can any of you tecchies prehaps advise me on what kind of power figures would be available from a 2nd gen FC running a T88 single turbo set up?
Any help is much appreciated.
grinder
isnt that what john ( 88gtr ) runs
... off to check ....
The tightest man on earth
:Giggle
grinder
i assume a t88 is bigger than a t78 ??
but this is what john runs...........
342rwhp@7100rpm @0.94 bar
358nm @6000rpm
WGT RB
FD Rotor housings
FD Corner seals and springs
FD Stationary gears
Mild street port
3mm Apex seal
Trust T78
Trust wastegate
Trust divided manifold
Secondary plates removed in TB
Microtech LT8
LM-1 Wideband
Walbro 255ltr/hr FP
1000cc secondarys
HKS BOV
V-Mount Bar and Plate Intercooler
76mm Piping
Vertical Radiator
HKS Super Drager/3in system
Exedy Single Plate
you thinking of an FC now ???
:Giggle
Freddy
why is he running such low boost?
Poss a fc, have my eyes set on one here. :)
grinder
low boost means long engine life :)
and i would be happy at 342 RWHP - saying that a standard turbo is only 202 at the fly :)
are you gonna splil the beans on the FC then ?
:Giggle
Freddy
Not yet, but I may well do when I see her on Friday :D
Then the T88 FD would have to go :(
88GT-R
QuoteOriginally posted by Freddy
Hi Freddy,
I was pushing my injectors near the limit at that boost. I will be revamping the fuel system next year, for some big flow. For the T88 you will need port work loads of fuel and a fair bit of R+D on the ecu settings.
I am getting full boost at 4600ish, building from 3700. The T88 series is very large and as long as you are not planning on running her for daily use, you will be able to put down a fair bit of power. BTW if you look through the older Jap catologues, Trust never designed the T78 and T88 for the FC. Having the T4 footprint allows them to fit though.
If you need any advice what so ever, give me a shout as there is alot needed to run these systems safely.
John
88 GT-R
Freddy
Hi John,
Thanks will need your advice once I have her full spec. I would have thought the reasoning for running low boost may have been due to fuelling issues.
I suppose running the V mount on yours plays a major part in any big turbo set up such as this.
