Best Place For A Dump Valve
Started by scoobster, November 16, 2004, 07:27:04 PM
scoobster
I was told a while ago that the closer you can get the dump valve to the throttle body the better!!! is this true on the RX???
I am just about to order some samco hoses to fit my HKS IC hard pipes and was just thinking about getting a samco T piece to fit just before the inlet elbow after IC and fitting a dump valve there what do you guys think??:D
Cheers Lads
jonrx7uk
As close to the Throttle body as possible is what i was told as well..
Makes sense really.
Jon
scoobster
So if i was to fit a T hose just after the outlet from the IC for a dump valve what should i do with the standard valve and it\'s pipe work? :confused:
QuoteBest Place For A Dump Valve
Engine bay.
