fitting magnecores
Started by turbotink, March 08, 2007, 06:41:07 PM
turbotink
hi guyz n gals what do i need to remove to fit the magnecores ive just purchased lol took the intercooler elbow off today to have a look and theres no way i can get to anything.has anybody done this and if so is anybody willing to giv eme a hand over the weekend lol,
interloper393
think you have to remove the plenum maybe? i know with mine off at the mo you can get to everything..
gonzoninja
I did it without removing the plenum. remove the elbow and the oil filler neck (it has a couple of bolts which are hard to get to but not impossible. One at the top and one down the side, with this off you can get to everything.
turbotink
will the kneck not leak oil everywhere then and can you remember what size nut it was mate as ill do it at work and have very little tools there lol.cheers
interloper393
i`ll have a guess n say 10mm :P
bobert
oil will not come out. their is two 10mm nuts on the top and one on the side. a 10mm socket and ratchet will do.
bob
turbotink
cheers peeps will do this tomorrow and let you know the outcome,
thanks
