One headlight not coming up!
Started by mikeeech, October 21, 2004, 05:35:43 PM
mikeeech
Took my FD for a spin last night... When I put the lights up the drivers side made a kind of odd grinding noise and wasn\'t raising at the same speed as the near side...
After a bit of a play with them (putting them up and down) the drivers side now doesn\'t come up at all.
It seems to make some clicking noises as though a relay is opening and closing.
Before I take it all apart has anyone had anything similar?
Mike
gsb876
Most likely cause is the motor on the light failing, will either require repairing or replacing, if you see any rx\'s on here for breaking ask for the motor matey;)
