Author Topic: Non-Sequential Turbo Conversion information  (Read 6914 times)
Online clive
  • MRC Founder/President
    • http://mazdarotaryparts.com
« on: May 12, 2004, 10:43:27 PM »
For all those who have wondered about doing this
http://www.scuderiaciriani.com/rx7/non-sequential.html
Offline Martiny
    • http://saturn.esnanet.com/martin/mandm.nsf
« Reply #1 on: May 13, 2004, 09:25:18 AM »
Thanks for that one, Clive.
What I am looking for is a quick way to convert to non sequential , for diagnostic purposes. (Trying to solve a secondary boost problem)
I have seen a post about this on the USA RX-7 (big list), but i cannot find it again. I also thought there was a website but cant find that either.
Offline Tintin
« Reply #2 on: April 07, 2006, 10:38:52 PM »
That link is now dead , found the new address the other day its http://www.fd3s.net/
12.8@110.64 at RS4:Thumbs-up
Offline vxer
« Reply #3 on: April 17, 2006, 07:21:46 PM »
Quote from: Tintin
After having read thought that link, i\'m still unsure exact what a non-sequential conversion actually does to the behaviour of the car under boost.
Both turbos now run simultaneously? Anyone care to summerise what the advantages are?
 :driving
Ta, Paul.
Offline Tintin
« Reply #4 on: April 18, 2006, 06:21:01 PM »
Hiya mate ,
Yeah both turbos run simultaniously , this takes slightly longer to spool them up but thats not always a bad thing , might make my baby a bit easy to launch , you get a predictable boost curve , if you\'ve ever had that second turbo kick in on a corner you\'ll know its not nice , think you may bet more power due to cleaning up the inlet and exhaust paths in the turbo thus making the turbos more efficient , but the best bit is losing all those vac hoses in the rats nest
I\'ve not done mine yet but will be doing soon so all the above info is what I\'ve gathered from others and may not be 100% correct , I know one member who runs non sequential - Donato , and he makes some decent times on the strip
Hope that helps
Paul
james01uk
  • Guest
« Reply #5 on: May 12, 2006, 11:31:18 PM »
its cool :god
Offline interloper393
« Reply #6 on: July 19, 2006, 04:36:59 PM »
so making your 2 turbo`s work as one means you cn remove alot of the vac hoses?
Devil\'s Refugee
  • Guest
« Reply #7 on: August 08, 2006, 12:28:05 PM »
Would running twin hybrids not help alleviate some of the lag when doing the conversion ?
Shyne
  • Guest
« Reply #8 on: August 11, 2006, 10:03:37 AM »
Got to say, I loved it, If you\'re intending to drag or drift then its a beautiful setup for predictability, no dip at 4.5k, encourages a more detailed tuning approach to decrease spool delays on the primary (clipping the primary wheel brings it down also) and boost all the way to town, the perfect intro to a single!!!
Like I said on the other thread, if anyone is interested in doing this, I have my old NS twins, Y-pipe, intake etc for sale as the lure of a single after driving NS for 2 weeks was to great, seq twins are great for a stock car, but if you\'re a boost freak like I\'ve always been, theres only one way forward!!!! 8o)
Offline carterjohn
Offline Rixio
  • Banned user
« Reply #10 on: September 20, 2006, 08:40:19 PM »
How to Do the Poor Man’s Non-Sequential Turbo Mod
Here’s what I did:
1. Wired turbo control door open and removed actuator rod from door mechanism.
2. Removed lines/plugged lines to charge control.
3. Removed charge relief and capped hole and vacuum line (I have since put it back on, but didn’t hook it back to the vacuum line.
4. Wastegate: Left the direct pressure line (with restrictor) in place.
Removed/capped the line that went to the solenoid.
5. Pre-control: History.
6. Installed down-pipe.
I’m waiting for my A/F gauge to come in, and I’ll be running to Home Depot for the parts necessary to turn down the boost a bit, per Broooks’ web site.
David Liberman
david@feet.com
This may make sense to some but i dont have a clue...
Rixio :Thumbs-up
Offline Tintin
« Reply #11 on: September 20, 2006, 09:09:18 PM »
I\'ve now done the proper non sequential mod , I\'ll be able to let you know what its like soon hopefully as my cars almost back together , just waiting on a few bits to finish it :D then the long run in process :(
Its gonna feel like a completely different car I think , I\'ve probably lost some low down power and torque due to going non seq , guessing the large street port might lose me a bit more low down torque and a new single clutch instead of that bugger of a twin that was on before , hopefully she\'ll be easier to drive in traffic and a bit easier to launch off the line
Offline Tintin
« Reply #12 on: September 20, 2006, 09:12:17 PM »
Rixio - Sorry ment to also say that if you want a lift doing the conversion ( poor or proper ) give me a shout and I\'ll give you a lift , poor mans should be a doddle compared to the proper
Offline rayrx7
« Reply #13 on: May 08, 2007, 12:41:55 PM »
Hello guys ,
now i decidet to go alsow full non sequential. But now my question. How would  the Boost from the second Turbo be controlled? I know that the first Turbo has the wastegate door installed,but no actoator control the second Turbo. How can you get an stable Boost? I have an Profec B boost controler that actuate the wastegate.
Thanks for ur infos
Offline Bob Monkhouse
« Reply #14 on: September 12, 2007, 08:25:38 PM »
Just had a quick flick through coz I havn\'t got time at the mo. for an in depth of the non seq. conversion. Lets just say that I did it on our Grants car and, **** me sideways, it was 40 well spent hours (some time spent matching ports and polishing turbots etc. When I have a bit of time I \'ll post some pics and a more detailed report of what I did. The source of my info was a yank RX site -fds3.net- very informative and v.helpful
