Author Topic: Rotory Engines on Gas Discussion.  (Read 12277 times)
Offline CharlieP
« Reply #30 on: May 12, 2011, 05:55:25 AM »
Awesome!! Thanks for the info...will be doing an LPG converison on my rex this year! :)
Offline shaunwil
  • Extra Special Moderator
  • Global Moderator
« Reply #31 on: May 12, 2011, 12:49:30 PM »
Blimey, I\'m running an Impco 305 on mine with a E Vapouriser.
Did something daft with the system over the cold snap and have only just fixed the issue. I plumber the vapouriser into the heater line, but didn\'t realise the heater had a vent. When I was turning the heater to cold it was freezing the vapouriser over, I\'ve just replubed a bypass pipe in so I can run the heater on cold !
Shaun
Offline Ultraman_Cosmo
    • http://www.myspace.com/djphilmanns
« Reply #32 on: July 12, 2011, 10:22:48 AM »
Our RX8 has been running on gas since 57000 miles, now has 94000 on it with no issues. Did a comp test at the weekend and all looks good. It covered 35000 miles last year so was a cost effective move! It uses an egas 8 cylinder kit and a modified ECU. Phil
Cosmo 110S,  RX4 Coupe, RX7, RX8, JC Cosmo 20B, NSU Ro80\'s etc......
Offline shaunwil
  • Global Moderator
« Reply #33 on: July 12, 2011, 12:46:50 PM »
Lovely ! Where did they put the tank ? Is it a dual setup or pure gas ?
Shaun
« Reply #34 on: July 12, 2011, 01:39:41 PM »
Hi Shaun, it\'s a dual setup. 50l tank in the boot. The reduction in boot space has not really caused an issue. Around 150 miles to a tank which means frequent refills but at around £30 to fill it\'s not a bad saving.
Phil
Offline shaunwil
  • Global Moderator
« Reply #35 on: July 12, 2011, 05:26:14 PM »
I run round with only 25lt usable tank, without the petrol setup at all !!! Get 100 mile range !
Makes long journeys interesting, did rotorstock last year in the 1st gen !
Shaun
« Reply #36 on: July 12, 2011, 08:12:17 PM »
you\'re a brave man!
Offline shaunwil
  • Global Moderator
« Reply #37 on: July 12, 2011, 10:47:31 PM »
Had it like that for over 3yrs now :Giggle
Want a bigger conformal tank from NZ in alloy and get them fit where the fuel tank is !
Shaun
