Author Topic: Super Pro PU bushes full kit  (Read 452 times)
Offline jeff_fohlen90
  • Please ta meet ya'!
    • Swansea
    • EyeforCreative Design Portfolio
« on: March 08, 2017, 12:05:10 AM »
I have available a full Polyurethane bush kit from Super Pro which covers both front and rear of the FD suspension. I have also included the ARB bushes front and rear as part of the sale (brought separately). Looking to strictly sell as a full kit at £400 posted. If you only wish to buy one particular part, I will look up the item number and offer it close to or matching current OEM price. The following is part of the kit -
SPF2821K   1   Front Upper Arm, Inner Bush Kit   4 Bushes, 4 Steel Tubes, SuperPro Grease
SPF2822K   1   Front Lower Arm, Front Bush Kit   4 Bushes, 2 Steel Tubes, SuperPro Grease
SPF2823K   1   Front Lower Arm, Rear Bush Kit   4 Bushes, 2 Steel Tubes, SuperPro Grease
SPF2678K   1   Rear Upper Arm, Inner Bush Kit   4 Bushes, 4 Steel Tubes, SuperPro Grease
SPF2674K   1   Differential to Cross Member Bush Kit   2 Bushes, 2 Steel Tubes, SuperPro Grease
SPF2680K   1   Rear Shock, Lower Bush Kit   2 Bushes, 2 Steel Tubes, SuperPro Grease
SPF2675K   1   Rear Toe Control Arm, Inner Bush Kit   2 Bushes, 2 Steel Tubes, SuperPro Grease
SPF2676K   1   Rear Toe Control Arm, Outer Bush Kit   2 Bushes, 2 Steel Tubes, SuperPro Grease
SPF2677K   1   Rear Trailing Arm, Front Bush Kit   2 Bushes, 2 Steel Tubes, SuperPro Grease
SPF281928.7K Sway Bar Mount 28.7mm 2 Front ARB Bushes, 2 Rear ARB Bushes, SuperPro Grease
    • Swansea
Re: Super Pro PU bushes full kit
« Reply #1 on: March 08, 2017, 08:12:37 PM »
This has been sold.
